Topic: PAD FX2 DDJ-400
Hello,
I use Pioneer DDJ-400. How can I assign effects on PAD FX2? (PAD FX1 are preassigned but PAD FX2 are empty).
Thank you so much.
geposted Sun 29 Sep 19 @ 2:27 pm
PAD FX2 is not empty. its using the Loop Roll page.
If you wish to replace that with a different one, you have 2 options...
Option 1: Create a new PAD FX page based on the PAD FX page of the DDJ-400.
- Open the Pad Editor and edit the PAD FX page, e.g. change the Echo and Cut to other effect.
- Once you edit the PAD FX, close VirtualDJ
- Goto Documents/VirtualDJ/Pads folder and rename the pad fx.xml to pad fx2.xml (this will keep the internal Pad FX page available)
- Open VirtualDJ
- Change the action of the PAD FX2 from .. pad_page 'loop roll' to pad_page 'pad fx2'
Option 2: Download a custom FX page .. eg. this one https://virtualdj.com/plugins/?addonid=80402
- Change the action of the PAD FX2 from .. pad_page 'loop roll' to pad_page 'PhantomFX'
Option 2 is easier for me. Just do it! Thanks a lot.
