A little over a month ago i bought a mixtrax 3. From the start i had crossfader bleeding. After the free pro trial was up i purchased the home plus licence. Bleeding got so bad that i contacted numark and they are going to replace the controller instead of repairing it because it is so new.
My question is with the replacement controller will i have any problems with the licence i bought with the old controller?
Does the serial # have to match, because im sure the new controller will have a diffrent serial #?
Or will i be able to just plug in the replacement mixtrack and party on? (i hope this is the answer....lol)
Thank you Ricardo
Thank you Ricardo
geposted Thu 03 Oct 19 @ 7:05 pm
If your license is for a Mixtrack 3 then it''ll work with a Mixtrack 3 - any Mixtrack 3. The license is for the controller model, not the serial number.
geposted Thu 03 Oct 19 @ 7:20 pm
This is awesome news. Thank You
geposted Thu 03 Oct 19 @ 7:43 pm
