Topic: Mac OS Catalina w/ VDJ 2020
on launch of vdj i get this popup “TweetList.bundle” can’t be opened because Apple cannot check it for malicious software.
I have deleted and reinstalled vdj 2020 same popup exists upon launch.
geposted Thu 10 Oct 19 @ 1:00 pm
It's not a VDJ problem. It's your computer OS.
If you Google, you can find info and solutions.
from I updated I'm also having glitches problem.........if I'm renaming a song or going in the settings it freezes up for a couple seconds say loading
The bundle(s) in question use the vdj logo ...
That's what I thought & tried before posting...no help.. solution points to developer (vdj2020)
I have just switched from pc to macbook pro, It's asking to upgrade to catalina, i'm very dubious about this, question is, is this now safe to do so or not?
too many factors to give a yes or no
have you check that all your hardware is compatible?
do you understand all the changes in the new OS and how they will effect you?
I am on the latest OS for Mac and VDJ and have no issues
