hello all.
I'm having an issue with my "touchbar" at the top of the software. The big graph with both tracks on that you can touch and move around...
90% of the time, when I load a new track it will be that one my 'hand' grabs on that big top bar, but sometimes it will grab the track playing!! Surely shouldn't be happening, and I can't see that it's a setting... help!!
anyone had/has this issue and has resolved it?
Many thanks
Many thanks
geposted Wed 16 Oct 19 @ 6:42 pm
"Hand" grabs the active deck.
So if you switch active deck it will switch which deck it works on.
Settings to check:
autoPpf -> Set it to "On Load"
pflOnSelect -> Set it to "yes"
Finally, even with those settings enabled if you use "TAB" button on your keyboard, VirtualDJ will switch the active deck.
So keep that in mind!
PS: When a deck is active it's waveform becomes more bright / is drawn on top. Therefore it's easy to understand on what deck the "hand" is going to act upon.
Settings to check:
geposted Wed 16 Oct 19 @ 8:32 pm
Also, some rhythmwave views allow you to grab either wave at any time.
geposted Wed 16 Oct 19 @ 8:52 pm
Thank you phantomdeejay. I can't find 'autoPpf' anywhere
- can anyone help? I've looked down the settings list 4 times...
Tab works - thank you.
geposted Fri 18 Oct 19 @ 6:11 pm
Try autoHeadphones...
geposted Fri 18 Oct 19 @ 6:22 pm
