Is it possible to make the pitch go to 0% relative to the new song when a transition occurs while using Automix?
For example, say I start slowing down a song, then the transition occurs. Usually it the pitch will end up relative to the last song's pitch, meaning if the last song was slowed down, the new song will be slowed down. is there a way to change it to be relative to the new song's pitch and end up at zero?
geposted Fri 25 Oct 19 @ 2:44 am
