I must not be seeing something... I looked in the manual here:
https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/loops.html
I used to be able to click "IN" then "OUT" then "SAVE" to save the loop I just created. Now I'm using the PRO skin and no longer see a save button. How do I save the loop I just created with the IN and OUT buttons?
Windows 10
v8.4 b5352
geposted Fri 25 Oct 19 @ 3:19 am
Its right there in the link you posted.
Just scroll down to the "Pro Layout" part
https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/loops.html#savedloop
geposted Fri 25 Oct 19 @ 11:41 am
I see the "saved loops" panel which says:
'Clicking the play button will trigger a saved loop, or if the slot is empty will create a 4 beat loop* "
But I've already created the loop. I want to save it. I don't see the button that just says "SAVE"
geposted Fri 25 Oct 19 @ 1:00 pm
Just hit the button, if a loop exists that's what is saved
geposted Fri 25 Oct 19 @ 1:33 pm
The manual says it creates a four beat loop though, but not that it saves the current one... The current one was 8 beats... And kinda weird design decision for the "play" button.
But, despite the documentation and somewhat misleading UI, it did work! thanks.
geposted Fri 25 Oct 19 @ 6:47 pm
