Topic: Serial Number/OEM License Number Issues
I bought an EPSILON Quad-Mix a few months ago (right after tax returns) and it came with a disk to install VirtualDJ. My deck has a serial code on the bottom of it (starts with 01) and I got a popup when I opened up the program a couple of months ago talking about an update. I didn't bother, because I was still learning the basics. Now that I am relatively experienced, I decided to try and install the update. Next thing you know, it asks for an OEM License number. I just assumed that was fancy talk for a serial number, so I put mine in. After numerous attempts, nothing has worked and I am stuck with an outdated version of VirtualDJ. Can anybody help?
geposted Thu 31 Oct 19 @ 3:16 am
same here my serials online dissipated i had purchased back in 99 & 2000
I need my license for Virtual Dj....How do I get it.... I already bought it....... Can you please please help Me 😭😭😭😭😭
Just need to login inside the software with same login as used on site here :) that activates license on computer
https://virtualdj.com/manuals/virtualdj/settings/licenses.html
