or should I just not worry about it.
Unfortunately, I tend to be a bit of a perfectionist.
I know when the phrase starts where I have Outro marked in yellow in the image.
This is when I want to mix in my next song.
But as you can see - the blue marker bar is off and so is the count.
Can I fix that?
I have gone through a dozen Youtube video's and I don;t seem to be getting it.
Can I fix that?
geposted Sun 03 Nov 19 @ 5:18 pm
Also is there a way to get my song name titles back?
I was messing around with a skin - that hid the name - and I changed skins... and I have no idea how to get my song name back.
lol....
lol....
geposted Sun 03 Nov 19 @ 5:20 pm
geposted Sun 03 Nov 19 @ 6:28 pm
And check setting hideSongInfo
https://virtualdj.com/manuals/virtualdj/appendix/optionslist.html
geposted Sun 03 Nov 19 @ 7:01 pm
Can I fix that?
Can I fix that?
Press the "tap" button once in the skin, when aligned up where you want to set the first beat of a bar
(or drag the dark shaded background in the bpm editor)
geposted Sun 03 Nov 19 @ 8:33 pm
Got it - thanks!
geposted Sun 03 Nov 19 @ 8:50 pm
Hey all,
How is everyone. Safe I hope. Where can I find the tap button without changing to the old interface
geposted Sat 28 Mar 20 @ 7:53 pm
That depends which skin you're using. The manual explains where the tap button is on the default skin(s).
geposted Sat 28 Mar 20 @ 8:07 pm
