Hi all, I been using 8.2 for just over a month and suddenly my crossader has started going crazy whenever i slide from left to right and vice versa. I try to put it in the middle and it just flies over to either the left or right. Struggled thru a gig on Fri and have another this weekend. Ive tried putting a few sprays of electrical contact cleaner through it but no luck. Even tried Air duster but nothing seems to help.
Hoping somebody might have an idea in case my settings in Options may be out also. No luck on 2nd laptop.
Currently using:
Win 7
VDJ 8.2
DENON MC6000 MK1.
Regards
Currently using:
Win 7
VDJ 8.2
DENON MC6000 MK1.
Regards
geposted Mon 04 Nov 19 @ 6:26 pm
Hardware fault. Crossfader needs to be replaced.
If you dont have time to do that till your next gig, best would be to disable crossfader and mix the Channel/Deck Volume faders
geposted Mon 04 Nov 19 @ 6:29 pm
Thanks for that, i'll give the shop i bought it from a call tomorrow to see if i can get it done before the weekend.
Cheers
geposted Mon 04 Nov 19 @ 7:47 pm
If you have any canned compressed air, spray some in around the crossfader. It could also just be a small piece of dust or something hitting the contacts and making the fader go crazy. Blowing it out with canned air might be an easy solution.
geposted Tue 05 Nov 19 @ 12:58 pm
Thanks visionz5, been at it for a few days with the air compressed spray. I'll keep trying till i empty the can..Otherwise its off to the shop for a look.
geposted Tue 05 Nov 19 @ 2:31 pm
