I have had mapped one key(X) to load into playlist, and another(A) to load into sidelist.
This worked fine for a few years. Now it does not work.
When i press the"A" is scrolls down the browser.
I deleted the mapping and re-entered it, still will not work.
Those keys are fine when used to do a search.
Also tried other keys to no avail.
Here is the mapping.
A sidelist_add
X playlist_add
Anyone with suggestions?
A sidelist_add
X playlist_add
geposted Fri 08 Nov 19 @ 9:18 pm
I have deleted the mapping and started over. Still no luck
Tried different alphabet keys, no good.
Strangely enough i entered a number key and it works.
The a through z keys will not allow any shortcuts.
They do work when I type something.
Does not make sense.
Any ideas why the alphabet keys will not work.
This is the same on both systems(Desktop & Laptop)
geposted Sat 09 Nov 19 @ 6:24 pm
Setting BrowserSearchByFirstletter is probably enabled ? If so, the keyboard letter keys will not work if Browser has focus.
geposted Sun 10 Nov 19 @ 3:22 pm
Thank you, that was the problem.
I know I did not change the settings, that is what is a bit strange.
geposted Sun 10 Nov 19 @ 3:28 pm
