Hello,
I just upgraded to 2020, however I am having 3 issues so far.
1st. I tried downloading 2020 manually so I can download the 64 bit version which only downloads the 32bit version.
2nd. I noticed my Virtual DJ Folders in 2020 do not contain all the songs that I built up in 7.4
3rd. I have an issue with my looping, in 2020 when I change the speed of the loop on my controller, it isn't displayed on the screen. Also, if I change the loop speed on deck 2 of my controller it does change the speed on deck 1.
Interesting but frustrating, as I did not have these issues on 7.4...I finally have the font acceptable, not sure why the crazy-ness there happened. I wish I could edit the color of the skin as that light-ish gray is hard on the eyeballs.
I look forward to any help,
Thank You!
Thank You!
geposted Thu 21 Nov 19 @ 5:51 am
1) 64 bit version is available to download only when you run Windows 10 x64 OS
2) Is this the first time you run VirtualDJ 8 / 2020 on the machine ? VirtualDJ will have to convert your old Virtual Folders to new format. But it will do it only ONCE. So, if you tried version 8 in the past and you tried VirtualDJ 2020 now, VirtualDJ 2020 didn't reconvert your VirtualDJ 7 virtual folders.
3) Which controller is it ? Take a look on mappers tab in settings. What's the deck assignment for the controller ?
geposted Thu 21 Nov 19 @ 9:38 am
