What folder is Tag Info, Play Count, Year, etc? I set up another laptop and thought I had copied everything but 100s of tracks are missing a lot.
geposted Tue 26 Nov 19 @ 2:29 am
Tag info is on on the actual tracks, but usually only read when you add them, and the stored in the database.xml
The other VDJ related info - like playcount - is also in the database.xml file
Remember that you have more than one database.xml file if you have external drives
geposted Tue 26 Nov 19 @ 10:02 am
Ok. I copy pasted the database over to the new laptop again. I'm still missing a lot of info that is on the original laptop. Would you delete the entire music library and redo
at this point?
at this point?
geposted Tue 26 Nov 19 @ 10:10 pm
Any more advice would be great. I deleted the music and database on the new laptop. Recopied both and i still have a lot of genres and play counts missing.
geposted Thu 28 Nov 19 @ 4:00 pm
Oh thanks guys. I'm the only guy that's had this issue and there's no way to fix it. I'm out.
geposted Sun 01 Dec 19 @ 2:45 am
Is your music on your C drive, or another one? If another one did you also copy the database from the other drive?
geposted Sun 01 Dec 19 @ 2:47 am
They're both on C drive. I believe the string is the same. I'll check.
geposted Sun 01 Dec 19 @ 12:04 pm
Just copy the entire documents virtualdj folder from the old machine and make sure your music is in the same folder location
geposted Sun 01 Dec 19 @ 1:30 pm
I'm about a hundred tag edits in by now. I only have another hundred tracks to go. An afternoon of work.
geposted Sun 01 Dec 19 @ 2:04 pm
