Is there a script that I can use in the schedule event feature that will allow me to scroll the next 3 singers in the text scroller?
geposted Wed 27 Nov 19 @ 6:27 pm
the text effect? why are you wanting to schedule it? wouldn't a karaoke skin be better?
Answer; yes but I need to get what and why you're doing.
geposted Wed 27 Nov 19 @ 6:42 pm
During Karaoke play, I am used to having the next 3 singer scrolling across the screen because it speeds up the show if the next singer is ready to take the mic from the current singer. I like to display the next 3 because it gives both the next singer and the singer after them to either go to the bathroom or out to smoke without missing their turn as I will only call their name 3 timess before moving on to the next singer.
geposted Wed 27 Nov 19 @ 6:52 pm
doesn't a karaoke video skin do that for you?
I don't have any karaoke tracks to fully test but karaoke OSD skin gives you the next singers & tracks , I don't know if it switches off when a karaoke track is active.
geposted Wed 27 Nov 19 @ 7:03 pm
I found one that will do it. Only issue is that I like the video screen put the actual video in a box and the overlay show above the box instead of cutting off some of the lyrics on certain songs.
geposted Wed 27 Nov 19 @ 8:44 pm
give us a screenshot, [I don't have any karaoke tracks to test properly]
geposted Wed 27 Nov 19 @ 11:57 pm
