Anyone else have issues using the Freestyler effect? I have it in the correct folders but can't get it to show up in VDJ. I am having the same problem on both computers I use VDJ on. It started a while ago, before the 2020 update. I was hoping the update would fix it. :( I used to send bpm to Freestyler lighting software using the Freestyler effect. Thanks in advance for any help!
geposted Thu 26 Dec 19 @ 11:57 pm
Its now part of vdj
I can find it both 32 & 64 bit VDJ under Master -> SoundEffect -> other
It have to install from VDJ, settings -> Extensions
select tab effects -> other
Only appears as a master effect, not as a per deck effect
Note : may differ due to Home edition limitations ... You maybe find it in autostart which is an unreacheable folder with Home Version
geposted Fri 27 Dec 19 @ 12:38 am
Nicotux wrote :
Its now part of vdj
Thanks for your advice. I did that and the only thing I could find was Freestyler Midi Remote Control UI. Unfortunately that's not the extension i was looking for. The extension I'm looking for would send beats, Freestyler messages, etc. I just don't think it's available anymore. :(
geposted Sat 28 Dec 19 @ 12:48 pm
I have the same issue. currently running pro version of VDJ but Freestyler does not show in master effects in both folders other or autostart. Can confirm the dll file is in both folders and was installed from other in extensions of VDJ, any thought would be appriciated.
geposted Sun 08 Aug 21 @ 1:52 pm
geposted Sun 08 Aug 21 @ 4:45 pm
Hi Nicotux,
Thanks for your reply.
Tried that also still cannot get it to show in the folder or get it to work.
geposted Sun 22 Aug 21 @ 12:38 am
It only appears in the Master panel, Audio effect, in the folder "others" at bottom of the list
Note the GUI seems to be too big to be dockable - pro layout
bug with switching layouts need to select GUI multiple times when it disapears
geposted Sun 22 Aug 21 @ 1:51 am
