Why can't you turn off sync from DDJ SB3 controller?
geposted Tue 07 Jan 20 @ 3:20 pm
You can, read
The Manual
smartPlay
autoBPMMatch
autoKey
The Manual
smartPlay
autoBPMMatch
autoKey
geposted Tue 07 Jan 20 @ 3:42 pm
You can't from the controller. Not in the manual.
geposted Tue 07 Jan 20 @ 4:12 pm
You can,
they're settings, settings can be changed by script, also ALL 3 of these settings actually have script verbs to toggle
but why do you need to? you either want autobpm or you don't.
geposted Tue 07 Jan 20 @ 4:34 pm
I'm not a scrip person, and this is not in the manual. all i want do is turn off the sync after I match the bpm from my DDJ-SB3 controller.
I Have read the manual always, I'm not new to this software. this function is not mapped to this controller in Vdj.
geposted Tue 07 Jan 20 @ 4:41 pm
From what I can see, the sync button on the sb3 is simply mapped as 'sync', so this button already only syncs one time when you press it.
It does not active pitch lock or beat sync, so it seems like it already does what you are looking for?
geposted Tue 07 Jan 20 @ 4:46 pm
Sync Is Not Mapped to shift Sync Off on DDJSB3. Need I say more? I Have To go to the software to turn it off, When it should turn off by shift sync on my controller. Possible miss Programing of mapper?
geposted Tue 07 Jan 20 @ 4:56 pm
VDJ does not have sync on/off.
Other DJ software may have the ability for sync to be permanently on or off, but the sync button in VDJ does not latch. It just does its job when you press it, then it's effectively off again - that's it.
geposted Tue 07 Jan 20 @ 5:25 pm
Well that Sucks.
But my point was this does not work on Virtual DJ.
Thank you all for your time.
geposted Tue 07 Jan 20 @ 5:29 pm
With "this" being what?
You don't need to turn sync off.......because sync does not stay on.
geposted Tue 07 Jan 20 @ 5:41 pm
OK, Found This In DDJ-SB3 Manual
SYNC (OFF) button Press:
The tempo (pitch) of tracks on adjacent decks can be synchronized automatically.
[SHIFT] + press: Cancels the sync mode.
geposted Tue 07 Jan 20 @ 9:03 pm
If you want to know how it works by default in VirtualDJ, you should check the virtualdj manual for the device:
https://virtualdj.com/manuals/hardware/pioneer/ddjsb3/layout/deck.html
geposted Tue 07 Jan 20 @ 9:10 pm
SYNC: Syncs the tempo and phase of this deck with the deck that is set as Master (indicated with the M button in the 4 Decks default skin). The Master Deck is automatically by default (auto mode)
Hold SHIFT down and then use this button to manually set a deck as Master.
Once a Deck is manually set as Master, the auto-selection of the Master Deck will not be available. To return to the auto-selection, you will need to press the same button again on the Deck that is currently set as Master.
THIS is different so I see that it is an automatic feature in Vdj. Just wonder why it was so different on the other software. when I do sync the sync lights on controller light up but no lights on VDJ software. Damn auto feature. So I get it now. Just curios as I did it old school.
geposted Tue 07 Jan 20 @ 9:31 pm
To turn on or off the automatic matching options, see
https://virtualdj.com/manuals/virtualdj/interface/decks/deckbasics.html#pro (number 6)
geposted Tue 07 Jan 20 @ 9:50 pm
Thanks,
LocoDog
GroovinDj
Adion
LocoDog
GroovinDj
Adion
geposted Tue 07 Jan 20 @ 11:40 pm
