I use Virtual DJ only in my laptop, I like this program very much my question: Auto mix when it is turned on and I have the option remove already played turned on, the last position in auto mix ON always stays on the list ... for which it is not removed as already play ... is there any way to change this or set the time when songs after being downloaded from Auto mix to DECK are immediately removed from AUTO MIX to the last position? I am asking you for answer Thank you Pete B. but this last song even played still should be removed thank you it would be good how it can be set somehow. time after song is upload to deck is removed ...
geposted Fri 17 Jan 20 @ 6:38 pm
