I'm trying to map effect_active 'sampler' to an effect, like effect_active 'sampler' 'echo'
That works fine - echo is selected in the sampler effect slot, and I can turn it on and off
If I then combine it with another button, which I map to for instance effect_active 'sampler''cut', that works fine too
But the echo then stays on - which is great since I can then stack effects, even if the first effect is no longer in the sampler effect slot
But it gives me two problems
- Querying it using the same script gives me "false" when it's not the currently selected effect, even though it's running. So my LED turns off even when the effect is clearly still running
- If I click it again with another effect in the sampler effect slot, the first click will select it, and then a second click is needed to turn it off
Are my scripts wrong?
geposted Mon 20 Jan 20 @ 8:30 pm
          The script is correct, but there's indeed a bug when using effect_active this way, will see if it can be fixed.
    geposted Tue 21 Jan 20 @ 1:30 pm
          I always thought having a "sampler" slot odd, I'd have presumed having
deck sampler effect_active
would have been the way to go
geposted Tue 21 Jan 20 @ 1:36 pm
