Hi everybody
do you know how to active de mix effects crossfader function in the "Pro" or "performance" view.... it's ok in the essential view.... but not visible in pro view...
Thanks
Thanks
geposted Fri 24 Jan 20 @ 9:19 am
effect_mixfx_select "filter" ? effect_mixfx_activate : effect_mixfx_activate ? off & effect_mixfx_activate & effect_mixfx_select 'filter' & effect_mixfx_activate : effect_mixfx_select 'filter' & effect_mixfx_activate
effect_mixfx_select
effect_mixfx_select
geposted Fri 24 Jan 20 @ 9:27 am
Where exactly in the xml skin do we enter this? Was hoping it would just be a checkbox!
geposted Sat 25 Jan 20 @ 7:52 pm
Just add it to a custom button...
geposted Sat 25 Jan 20 @ 8:02 pm
they're not aimed at the skin.xml, more suited to custom buttons, keyboard keys, pads etc
but if you want to skin then define a button with one of these scripts as an action and place it
Can just add to custom button, with the action effect_mixfx amd button name to query
geposted Mon 27 Jan 20 @ 12:48 am
