Hi guys
does anyone knows what is this red spot on some cue points?
it can appear even on hot cue pads that i have dont use (didnt define)
Thanks
Thanks
geposted Sun 26 Jan 20 @ 5:25 pm
a picture as to what you mean...
geposted Sun 26 Jan 20 @ 5:26 pm
geposted Sun 26 Jan 20 @ 5:38 pm
The dot is the cue colour, if you didn't set a colour it's probably because you have the setting "nonColoredPOI" set to different or default.
geposted Sun 26 Jan 20 @ 6:03 pm
thanks
but if it was this, then "why the red dot is only in the first cue?"
geposted Sun 26 Jan 20 @ 6:06 pm
there's a cyan dot on cue 7..., it's there because a cue of that number exists
geposted Sun 26 Jan 20 @ 6:13 pm
thanks a lot for ur time
is any any chance to make it dissapear?
geposted Sun 26 Jan 20 @ 6:28 pm
Yes, when you upgrade to VDJ2020 it becomes lines instead :)
But it's color codes so you can see what cue point goes where in the track (see image below)
That is important info just like current play time and so on, so why would you want that to disappear?
Anyway... If you really want to, you can set the nonColoredPOI setting to "No color". Then they all turn white
Or set it to "Deck color", then they all get the color of the deck
geposted Mon 27 Jan 20 @ 2:02 pm
