Hey guys is it possible to map the jogvision pads so i can browse << back and forth >> through a song. my hercules dj4set had that option beside the sync buttons. i download the mapper for the jogvision not sure what to do, I Play a lot of reggae and dancehall so dont really need the pads i was thinking of using 3 to browse backwards and 4 to browse forward. anyone can help i would really appreciate it.i search the forum but could not find anything useful.
geposted Thu 30 Jan 20 @ 4:42 am
Sure, you can do that..
Simply find the entry for the pads in the controller settings, and change to seek +500ms for example
The pads have two modes on your controller.. .HotCues and Sampler, so perhaps choose for the mode you use least then
geposted Thu 30 Jan 20 @ 4:19 pm
Thanks
geposted Thu 30 Jan 20 @ 5:00 pm
