Hello,
I am trying to reset the timer (stopwatch) with a custom button. I tried several scripts to no avail, hence my forum post/request.
Thank you kindly for your help. I do spend time trying to figure this out before I post on the forums asking.
geposted Thu 30 Jan 20 @ 1:29 pm
I don't think you can.
geposted Thu 30 Jan 20 @ 1:37 pm
And now you can
BUILD 5522 (2020-02-06)
-stopwatch and stopwatch_reset actions
geposted Sun 09 Feb 20 @ 6:37 am
Thanks!!!..xD..I appreciate that!
geposted Sun 09 Feb 20 @ 3:28 pm
locodog wrote :
And now you can
I checked my build and mine is 5504.1571...how does one upgrade builds? I thought it updates automatically. Or at least it appears to when i get the message I always say yes.
geposted Thu 13 Feb 20 @ 12:58 pm
it's only in earlyAccess at the moment, you can get it by searching options for earlyAccess, tick yes and give vdj a restart
geposted Thu 13 Feb 20 @ 1:17 pm
Thanks!!!
geposted Thu 13 Feb 20 @ 1:22 pm
