Just a taster of the padpage only version of routine. [mac friendly]
nothing extravagant, maybe how it would be used with house/tech type music
I've made some skin compromises with cue names on the scratch wave [got rid of them or they piled up] and changed how cues look on the song position [got rid of shadow, slimmed cues down to 3pxl, got rid of the mask, cut then to half height.]
[wanting something different but not sure how]
I've added in a "Step Recording" function, [when recording it pauses after calling the hot_cue, if you want to do things slowly]
Switched the instant playback and looping playback to be on by default [makes sense even if the variable doesn't]
Some decisions to be made with pad names [currently a load of var information]
but after a batch of testing, it might be ready.
geposted Thu 30 Jan 20 @ 3:04 pm
Good One LOCO !
geposted Sun 02 Feb 20 @ 1:03 am
Another simple routine, just sharing ideas how you can add a bit of bounce to your mix in or mix out.
geposted Sun 02 Feb 20 @ 3:45 am
