hello pros
Doing file management and file library migration to clear up space on hard drives. I'm doing a wrong procedure somewhere. Please help, i have searched the forums and facebook groups, but most posts are old and dated for version 8.4 b 5504.
Virtual DJ Pro Infinity 2020 windows 10
Scenario : Three performance windows laptops, with internal HDs. One of the three has two internal HD installed. The space is getting limited. So i planned to copy all music files and database over to one external hard drive. Remove music files from the internal drives on all three laptops.
uninstalled Virtual DJ from all three laptops, removed all MP3 files. Reinstalled VDJ. Hot plugged external HD via USB. Had to copy over playlists and history. but all virtual folders are visible in VDJ. browser search recognizes all files.
My problem is: the virtual folders on the left side has duplicates of the same file. same file path to the external drive. i think VDJ is reading two databases. i do not have duplicates in the browser search. only in my "crates or the virtual folders"
how can i fix this and not lose my previous saved information?
( [virtual dj duplicates.jpg] )
geposted Sun 02 Feb 20 @ 5:16 pm
There is a discussion about this issue already. There are some pointers there that might help.
Discussion Link:
https://virtualdj.com/forums/233210/General_Discussion/Database_issue_can_t_figure_out_.html
Discussion Link:
geposted Fri 07 Feb 20 @ 12:54 pm
