hey, ive turned on my vdj8 at a gig yesterday only to find that my cue points are all gone and songs appear as if ive never played them before . anyone knows how to retrieve such database on a mac ?
geposted Sun 02 Feb 20 @ 5:50 pm
Sometimes just a restart of vdj will sort this. Try that before we dig deeper.
geposted Sun 02 Feb 20 @ 6:22 pm
Having the same issue, i've restarted vdj at least 8 times now, nothing seems to work...
geposted Sat 01 May 21 @ 8:55 am
Try restart the computer or CTRL ALT DEL
If the database is "empty" with missing cues, bpm etc. its probably due to a frozen process that already has taken the database (for some reason, perhaps closing lid on computer with software running or something)
Restarting the computer will start fresh though and all should be fine again ;-)
geposted Sat 01 May 21 @ 10:57 am
Hi,
This just happened to me yesterday, recorded a mix with those trackname cuepoints that VirtualDJ automatically adds, opened the mix today, all cues are gone! Including the ones I added manually.
I restarted vdj & my computer several times, still same issue.
How do I fix this?
How do I fix this?
geposted Mon 14 Jun 21 @ 8:44 pm
DJ Meku wrote :
Hi,
How do I fix this?
How do I fix this?
Check your database.xml file - that where they get stored
geposted Tue 15 Jun 21 @ 6:38 am
