I am making some custom mappings for my midi controller with virtual DJ. On my controller, each deck has its own Time/Rate and Freq/Amount knobs.
Currently, I have the Time/Rate knob controlling the Filter effect for easy high and low pass.
What I'd like to do is set an If condition. When no effect is selected, that knob will control the filter as stated above. However, when I click the effect button( to have an effect such as Flanger active), I would like that knob to control the STR setting. Then, once i click the effect button(turning off the effect, for example flanger), that Time/Rate knob will go back to controlling the Filter effect.
Is this possible? If my ask isn't clear, let me know so I can try to explain better!
Really appreciate any help here!!
geposted Sat 29 Feb 20 @ 6:43 pm
Maybe this, [depends on how you use slots]
effects_used ? effect_slider 1 1 : filter
are any fx active? yes control slot 1 , slider 1 : no control the filter.
geposted Sat 29 Feb 20 @ 7:45 pm
That seemed to work!! Thank you so much for the fast reply.
If you don't mind I have another request as well, currently I have 4 buttons for effects and for example, my 'delay' button controls the Cut FX, my 'flange' button controls the Flanger FX. Is it possible to have two or more effects going at the same time? Right now if i have the cut effect active, then hit the flange button, it kills the cut effect and activates the flanger.
I would like to map it so that an active effect is not killed when hitting a button for another effect but rather use the buttons like on/off switch so that the effect can stay active until the button is pressed again(to deactivate it).
geposted Sun 01 Mar 20 @ 3:43 pm
save me some pain, show me your mappings.
geposted Sun 01 Mar 20 @ 4:02 pm
Hopefully this helps, let me know if you need another screenshot
geposted Sun 01 Mar 20 @ 4:46 pm
Doesn't really save me the pain of typing it out...
and since you've only shown the one, I'll have to guess a bit
probably this
var 'shift' ? effect_active 'cut' : effect_select_multi 'cut' & effect_active 'cut'
probably this
geposted Sun 01 Mar 20 @ 7:08 pm
