Calling FX, pros; super quick and easy. cons setting the dials/buttons right takes vital seconds
Calling FX with script, pros; quick and everything is exactly as you wish. cons; script isn't easy and you only have a limited amount of buttons.
What if you could could have all the pros and none of the cons?
Call an fx super quick with the dials exactly as you wish.
The idea is, this plugin you download and make 10 copies of it, [maybe more]
in practice time you take an fx you like, put it on slot 1 and find some nice settings, this new plugin when you press "SAVE", saves whatever is in slot 1, the fx name, all dials, all buttons, everything.
you then find this plugin in the plugins folder and rename the .dll and the .ini to a name that makes sense.
so stuff like echoShort.dll + echoShort.ini, echoLong.dll + echoLong.ini etc
Then in show time you select "echoShort" to a slot like any other fx, when you turn this on it calls all the presets, turns the fx on and populates the slot where "echoShort" was with the fx you want.
In truth this is a throwback to when all vdj fx were .dll files , when we could copy+rename and a bit of 0xHax. but native fx killed that, until now.
geposted Fri 06 Mar 20 @ 8:12 pm
So I was talking to phantomDJ and I've made some changes to what he thinks would be useful, more about that project another time, but in conversation something I've been thinking about for a while came up.
An fx were you can sort of make it yourself
as proof of concept, I made my effect control the native cut fx but I made dial 1 beats [because despite strength being the default for slider 1 in vdj fx, for me beats is the pertinent feature of the fx]
And the thing is it was all 'programmed' by vdj script, reasonably short script at that,
this is a basic example but there's bound to be ideas
get_text "effect_slider 'diy' 1 & param_cast 'float' & effect_slider 'cut' 2" & param_cast 'text' & effect_string 'diy' 1 & get_text "get_effect_slider_text 'cut' 2" & param_cast 'text' & effect_string 'diy' 2 & get_text "effect_active 'cut' on" & param_cast 'text' & effect_string 'diy' 7 & get_text "effect_active 'cut' off" & param_cast 'text' & effect_string 'diy' 8
geposted Tue 10 Mar 20 @ 11:51 pm
