Is it possible to display in the browser or sidepanel / automix that a song's POIs were manually edited?
Is it possible to restore a song's POIs to their defaults?
Is it possible to get a song to play according to the POIs sometimes but not always? Perhaps "if playlist title = _____"? Or "if preceeding track is ___" and/or "if following track is ____". I could duplicate an mp3 and edit each one separately. Is it possible to do that without duplicating the mp3 (or other format file)?
geposted Sun 08 Mar 20 @ 3:21 pm
1 manually mark them
2 no.
3 maybe, what do you mean by "play according to poi"
2 no.
geposted Sun 08 Mar 20 @ 11:38 pm
To reset to default POI, simply reanalyze the song
geposted Wed 11 Mar 20 @ 2:02 am
That is a problem. I have noticed some flies with unknown bit rates. I have been reanalyzing them. Now I see that I loose my cue points. So what I now do when I come across an unknown bit rate is drag the file to a deck. The bit rate returns and my set cue points seem to stay intact.
geposted Thu 12 Mar 20 @ 12:07 am
