I switch from serato dj pro, using numark ns6ii, there is some setting i want to set like serato dj, but how to?
1.i want it like serato/rekordbox sync tempo fader together when i press sync button, it mean after i pressed sync, when i set tempo fader A and B decks will set same time.
2.how can i use fx on my filter like pioneer dj "sound color fx",i want switch filter and pitch with filter knob.
3.can i set fx beat? for example: echo 1/4, 1/2, 1 ,2 beat
4.why in vdj slip mode not like serato and rekordbox, it mean when i turn on slip mode,it only happpen i touched jogwheel, its not working music pause.
5.i owned numark ns6ii, it have "pitch bend" button , how can i use it pitch up or down, in vdj it only speed up or slow a sound.
thx for helping.
thx for helping.
geposted Mon 09 Mar 20 @ 8:06 pm
1 the script is pitch_lock
2 see 7 https://virtualdj.com/manuals/virtualdj/interface/mixer/audio.html
3 see Using FX https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/effects.html
4 because we're not serato nor rekordbox, we like choices, remap your playpause button to
play ? pause & slip on : play & slip off
5 can be scripted
5 can be scripted
geposted Mon 09 Mar 20 @ 8:23 pm
5 how to questions on how to change VDJ behavior
- all answered with suggestions/solutions within an hour
Very impressive!
Very impressive!
geposted Tue 10 Mar 20 @ 9:50 am
Actually much better it would be to enable the autoPitchLock option (which BTW is enabled by default in VirtualDJ 2020 PRO skin)
When autoPitchLock option is active the pitch lock engages automatically when the tracks are in sync. When the tracks are not synced then each pitch slider works by it's own (and therefore one pitch slider does not drag the other around as it happens with pitch lock)
Also about 5:
Pitch Bend means just that: BEND (temporary action)
You can change the buttons to do almost anything you like. For instance you can use:
shift ? pitch +0.01 bpm : pitch +0.1 bpm
or
shift ? pitch +0.01 : pitch +0.1
or
pitch +0.5
or...
The possibilities are almost limitless
geposted Tue 10 Mar 20 @ 12:59 pm
@all thx for helping, i will make a video to explain my problem i have.
geposted Fri 13 Mar 20 @ 3:53 pm
I HOPE TOO!slip+brake!!
geposted Sun 10 May 20 @ 12:51 pm
@tonyshan007
You were given an answer to this in one of your other threads.
Please stop creating multiple threads about your issue and hijacking other people's topics.
geposted Sun 10 May 20 @ 1:01 pm
