Hi VDJ team,
If I purchase home plus but decide to upgrade my dj controller in the future will I need to purchase again or can it be switched?
geposted Tue 10 Mar 20 @ 2:12 pm
Home Plus is for a single, and specific controller (the one you bought license for).
And hence only valid for that controller.
Should you upgrade/change controller in future, you would need a new license.
If you consider that a possibility, the PRO license might be a better choice, since it allows any and all controllers, unlimited choice.
geposted Tue 10 Mar 20 @ 2:14 pm
