Hi All,
I am a long time user, but I just returned to the site after a bit of a hiatus.
One thing that I noticed is that I had a tough time trying to find the PC requirements for VDJ.
I feel that the drop down tab for 'Products' should include a link for PC requirements. Currently someone new who is seeking to use the software has to dig pretty deep to see if their PC is usable. It should easily be a visible part of your products information.
Just my thoughts...
Clay
Just my thoughts...
Clay
geposted Sun 15 Mar 20 @ 2:23 am
geposted Sun 15 Mar 20 @ 7:30 am
Also, there's not that much to say about requirements.
If your computer can run windows 7 or higher, it should be able to run VirtualDJ, so the easiest way to know for sure how well it will run is simply download it.
geposted Sun 15 Mar 20 @ 7:43 am
Yes Soulconnexion, I feel THAT link should be in the drop down tab for 'products' and it should show as 'system requirements'.
Adion, not everyone will automatically know that the software will work with their system. What if they have a very slow older machine, or what if for some reason they are still running Windows XP? Why should they have to search further into WIKI to find this info?
geposted Sun 15 Mar 20 @ 12:20 pm
It's listed right on the download page as well.
geposted Sun 15 Mar 20 @ 12:36 pm
