Forum: Addons
Topic: Controller 2020 by DennYo - Page: 5
Denny DennYo wrote :
Version History 3.0.5
-Bugfix - the width of the right padbutton 2 on 2 deck middle extra corrected
Thank you very much for such an awesome new skin (2020) and for replying to, and addressing and fixing our concerns! :)
goin.
Version History 3.0.6
-Bugfix - the Custom Buttons on toggle pad and cue area are visible, now
DennYo
Thank you for the scripts much appreciated
DJBernieB
Version History 3.0.7
-add- KEY menu like the original Skin
Text goes over other text
The bottom of the letter g in reggaeton is alo cut off...
h
Hello joaolabbe,
you doesn't use the newest version. The size of textzone (artist and trackname) are correct since last update.
The correct size of the cuetext comes on the next update.
My interfase reads:3.0.7. I thought it was the latest. I there a new one. I keep re-installing the skin to get the update.
h
Hello joaolabbe,
3.0.7 is the newest online Version.
your screenshot is older than the 3.0.7
in the 3.0.7 is KEY setting feature on the Songinfo Area. show screenshot -->
There's clearly an issue with the way the extensions area works in VDJ...as it doesn't work properly.
I can tell from the difference in the key display of the skin that I don't have the latest version, yet VDJ is not telling me there's a newer version.
Exactly . There is no way of telling in what update you are at the moment but from my screen shot this is what I got:
Version History 3.0.8
-Bugfix - Textsize of the Cue Buttons
-Bugfix - KEY move arrow in big deck Video was on the wrong position
-add - you can turn off the border arround the Song Infos Pitch/KEY/Gain/Rate ("Skin Button"/Deck Setup/Border SOng Infos)
hi
is the latest update aprooved yet ?
i only see in extensions & have in vdj 3.04
romeodan wrote :
hi
At the moment is 3.0.7 aprooved.
That orange color on the selected file and on the selected track at the browser area,is there a way to disable it?
yes , but this is what is installed ..
maybe it is 3.07 but says 3.04 ?
search in the skin.xml the row
<define color="browserliststripefocus" value="#C46A12"/>
In this row you can change the color.
There are two lines with this content, please change them.
when you found a good color please post the htmk #xxxxxx Code. I will change it for the future.
check this color: #587190
Uninstall the skin and reinstall from the extention hub.
I have it doawnload just at this moment and i get the 3.0.7.
you are right !
thanks !
19%
