Hi, I just downloaded the latest version of Virtual DJ (2020) 32 bit and I don't see the option to manually adjust the beginning point of a loop. In a previous version of VDJ (8?) there was a little dial in the loop section that would enable you to move the beginning point of a loop forward or back, but I don't see this option in the current version. I checked all the different layouts (starter, essential, pro, etc.) and I can't find it.
geposted Sat 28 Mar 20 @ 4:55 pm
Only in PRO and PERFORMANCE layouts youl'll find the "LOOP" panel
you can toggle between "Loop define" & "Loop adjust" and some other if enabled in group
geposted Sat 28 Mar 20 @ 5:22 pm
Thank you! A little different from the older versions, but it seems to work just fine, I really appreciate it.
geposted Sat 28 Mar 20 @ 5:46 pm
