Hello, I’m new to the forum so to start thanks to those who find time to make themselves available to others,
and keep that spirit of self-help.
My question: is it possible that the full-screen browser window falls back to the simple slide of the track on the deck?
Is there an order for that.?
I use vdj8 skin oldschool and the like..
very thanks
very thanks
geposted Fri 03 Apr 20 @ 6:26 pm
Not entirely sure what you meant, but if you turn on browserAutoZoom in settings, and then try a skin that has browser zoom. Is it somewhat that you had in mind?
If so, its possible, and a skin could in theory then fallback to a small area when "out" of the browser
geposted Fri 03 Apr 20 @ 6:32 pm
hello,
What I mean is that when I open browser/zoom in full screen while i'm playing (not the mini browser),
I would like it to close automatically when I drag my track in the deck..
I avoid going to re-click on toggle button
Sometimes, it make it alone unintentionally
(sorry for my bad translation)
Thanks
Thanks
geposted Fri 03 Apr 20 @ 8:47 pm
As i said in the French forum a script would do
but all test ends with VDJ crash
load_pulse and browser_zoom are difficult to associate
this one is working per deck ... as a toggelable custom multibutton
repeat_start broff ? on & up ? nothing : repeat_stop broff1 & repeat_stop broff : off & repeat_start broff 133ms -1 & repeat_start broff1 ? nothing : load_pulse ? nothing : repeat_start broff1 33ms -1 & loaded ? browser_zoom off & repeat_stop broff1 : nothing
I think it is because load_pulse stay down when unloaded
geposted Fri 03 Apr 20 @ 10:09 pm
Not in front of a computer , but if memory serves, keyboard mapping has a On Load key which you could map as browser_zoom off
geposted Sat 04 Apr 20 @ 5:17 am
Ah yes djdad !!
Map keyboard key "ONSONGLOAD" to action "browser_zoom off"
geposted Sat 04 Apr 20 @ 9:28 am
hi,
"browser_zoom" in the mapper does a small zoom in the browser, it is different of the button "BROWSER/ZOOM"...
so i found it in "ONSONGLOAD" to action variable --->"toggle 'brow' "
but it it work only on the selected deck,
so i must select the deck before loading the track if I want it to work .. it’s not much better,
Is there a possibility to add "ONSONGLOAD" to action--->deck select --->variable --->"toggle 'brow' " ?
Thanks everybody for your contribution,
Nicotux, it will be easier for me to communicate on the French forum
thanks a lot
thanks a lot
geposted Sat 04 Apr 20 @ 5:14 pm
Which skin are you using and which controller (if using any) ? Quite weird for a browser panel to use a deck dependant visibility variable. Sure it's not $brow ?
geposted Sat 04 Apr 20 @ 7:42 pm
skin oldschool de Zanard, the button is at the very top in the middle of the mixer
I just saw that there wasn’t this button in the other skins,
then i did $brow but it doesn’t react
geposted Sat 04 Apr 20 @ 8:20 pm
Skin have some issues :
var name is 'brow'
but implementation is erroneous and the local var depends on deck initially selected
Map keyboard key "ONSONGLOAD" to action "deck master set brow 0 & deck left set brow 0 & deck right set brow 0"
this will do the trip
La variable est bien 'brow'
mais c'est un erreur de conception: l'utilisation d'une variable locale fait qu'elle dépends du deck initialement sélectionné
Map la touche du controlleur clavier "ONSONGLOAD" avec l'action "deck master set brow 0 & deck left set brow 0 & deck right set brow 0"
ça le fait
var name is 'brow'
ça le fait
geposted Sat 04 Apr 20 @ 9:55 pm
yes Nicotux,
super ça marche , c'est quand meme plus pratique..
mille merci et au plaisir
djdad : my controller is only timecod vinyl + smac pro4 or multitouch + smac pro4
byby
byby
geposted Sat 04 Apr 20 @ 11:57 pm
