hello, i have tried everything.
im using djm-750mk2 mixer, high sierra mac. everything works with rekordbox.
if virtual & rekord works together there is a timecode signal, everything perfect.
if i close rekordbox that timecode single stops!
a little search show that pioneer utility outputs goes 'grey' and virtual dont see 750mk2 as a driver (only outputs)
please, can anybody help?
geposted Tue 07 Apr 20 @ 5:44 pm
Well you should probably not run both at same time, not sure that even works.
Just use VirtualDJ alone and set timecode and audio settings correct inside the software
The settings should be somewhat similar to the DDJ-800
https://virtualdj.com/manuals/hardware/pioneer/djm850/installation.html
For timecode setup, see here :
https://virtualdj.com/manuals/virtualdj/settings/audiosetup/timecode.html
Should work fine, seen a lot of users with 750 mixers :)
geposted Tue 07 Apr 20 @ 5:48 pm
Overdoing the levels on that mixer! Ouch!
geposted Tue 07 Apr 20 @ 6:34 pm
Most likely the Inputs (for DVS) on the 750MKII are "locked" and require VirtualDJ to "map" and unlock the firmware features of the device and offer official support in order to use it with Timecodes.
We don't currently have a DJM-750MKII but we could arrange for a Remote session and make it happen,. Let me know if you could work with us remotely on this to send you further details to your email.
geposted Wed 08 Apr 20 @ 11:33 am
