Hi, i bought a home license, paid 57 euros, but after 10 minutes the program keeps saying that i have to buy a license if i want to continue mixing with my controller. Now i feel like i paid 57 euros for a problem that isn't fixed. Can someone help me out?
geposted Fri 10 Apr 20 @ 3:18 pm
Log in to the software in the settings menu with your forum username and password. Other than that you may have bought the wrong license.
geposted Fri 10 Apr 20 @ 3:31 pm
If you are logged in correctly, this may happen if you are trying to use a feature that requires a Pro license
E.g.
- you are using an "External Mixer" Audio setup (with deck 1, deck 2 etc) or Timecodes and Line Inputs instead of the default setup of your controller which is Master + Headphones
- you have removed the VirtualDJ logo from the Video Output
- you are trying to broadcast to a Radio server
As far as i can see from your Account stats , at some point you applied an External mixer setup, and that could be the reason you are getting the message.
E.g.
geposted Fri 10 Apr 20 @ 6:04 pm
