Is it not possible to broadcast direct anymore as in older versions, because(shock, Horror,lol) i don`t do social media of any kind but i would like to broadcast to a select number of friends. I`m using vdj 2020 32bit and windows 8.1
geposted Wed 15 Apr 20 @ 5:01 pm
Yes, you still have all the options there.
Just click on the appropriate option.
https://virtualdj.com/manuals/virtualdj/settings/broadcast.html
geposted Wed 15 Apr 20 @ 5:19 pm
Yes i saw that but don`t you have to go through vdj servers. Used to be able to go direct from my computer to another
geposted Wed 15 Apr 20 @ 5:24 pm
Its still from direct from your computer to another...
The "through VDJ servers" is just an interface to make it easy to share, and for listeners to tune in :)
geposted Wed 15 Apr 20 @ 5:26 pm
Thanks Rune and Dan, must just be me misunderstanding, i`ll give that a go
geposted Wed 15 Apr 20 @ 5:29 pm
Before, a long time ago, you would see the tune in link in VirtualDJ as http://129.128.200.10/virtualdj.mp3 (where the numbers would be your IP).
You can still share same link to your friends if you want, find your IP here https://www.whatsmyip.org/
The link you now see in newer VirtualDJ, is just a nicer link, to your profile page at VirtualDJ with a radio player to tune in ...
But if you prefer the "old" direct to IP way, it still works as well ;-)
geposted Wed 15 Apr 20 @ 5:33 pm
That`s what i was looking for, thanks rune but the virtualdj route will do it
geposted Wed 15 Apr 20 @ 7:12 pm
