HI.
I was wondering if anyone knew the scripting command that I could use to turn shaders on/off from my keyboard. For example, if I'm in video mode and I want to override the video playing, I press say F1 and it turns on the shader-then F1 again to resume to the video.
I have had a look in the mapping section but I don't want to break anything, so help would be appreciated.
Thanks in advance.
Thanks in advance.
geposted Thu 16 Apr 20 @ 4:40 pm
Hello
video_fx_select 'Shader' & video_fx
geposted Thu 16 Apr 20 @ 5:58 pm
video_fx Shader
is enough
is enough
geposted Thu 16 Apr 20 @ 6:20 pm
Superb-Thank you for the info.
geposted Thu 16 Apr 20 @ 7:04 pm
