Topic: problem with the pitch bend function / mapping
Hi,
I have a problem with the pitch bend function.
Set up:
MacBook Pro mid 2012, MacOS Mojave
Denon MC 6000mk2
Virtual DJ8 v8.4 b5630
On my second MacBook I press the Pitch Bend "+" key respectively "-" and the song is plays forward or backward in four-fourth rhythm. Setting in mapping with pitch bend + key: "seek +4" and with the "Pitch bend -" key accordingly "seek -4". so far so good.
I take my 2nd Macbook with the same mapping settings but with another library of songs, only use the "pitch bend -" button works as expected. With the "+" botton there is no function.
Does anyone know advice?
thanks a lot.
geposted Sat 18 Apr 20 @ 8:42 am
