I have vdj2018 on my windows laptop and want to use the same set up on my MacBook. but I can only find the vdj2020 to download. is there a link to download the older version on my MacBook.
geposted Fri 24 Apr 20 @ 8:39 am
https://virtualdj.com/download/build.html
You can find the current build number in the config window.
geposted Fri 24 Apr 20 @ 8:45 am
how do I find the build number of the 2018 that I am using on my laptop.
geposted Fri 24 Apr 20 @ 8:49 am
As stated above it will be in the config window. May have changed but it will look like this:
geposted Fri 24 Apr 20 @ 8:52 am
sorted thank you very much going to try that.
geposted Fri 24 Apr 20 @ 9:01 am
