Hi guys I have been doing a lot of DJ streaming due to lockdown here in the uk I have streamed directly from virtual DJ. Which worked like a treat. But I’m after away to stream the video output to a second computer with NDI so I can pull the feed into OBS to the second computer. I can run OBS on the computer running VDJ & do a screen capture but it takes up a lot of resources on the PC I’m after away just to scream the video screen with NDI. Anyone help ??
geposted Tue 28 Apr 20 @ 4:25 pm
No one can help with this ??
geposted Wed 29 Apr 20 @ 7:02 am
nop, no NDI plugin for VDJ (Yet ?)
geposted Wed 29 Apr 20 @ 8:03 am
Have you tried NDI scan converter ? it will capture your screen and transformit into a ndi signal
geposted Wed 29 Apr 20 @ 8:30 am
Yes tried it OBS well capture the full screen & send it with NDI but I’m just after the Video screen to be captured without any drop in the video
geposted Wed 29 Apr 20 @ 9:36 am
Hi, im' not shure to understand. Can you make a pic of your installation ?
geposted Wed 29 Apr 20 @ 12:03 pm
you could try something like this if your video card has a second HDMI output. Send your video to the second output as an extended desktop.
https://www.amazon.com/Elgato-Game-Capture-HD60-PlayStation/dp/B01DRWCOGA/ref=sr_1_3?dchild=1&keywords=hdmi+video+capture&qid=1588173979&sr=8-3
geposted Wed 29 Apr 20 @ 3:28 pm
Not specifically what your after but I am playing around with this at the moment. Just from my Google searching earlier today.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3D4q1rXLcXRLM&ved=2ahUKEwifwZamgI7pAhXEgeYKHaWnAV4QwqsBMAF6BAgIEBM&usg=AOvVaw1q5m1_23CnjjNsaECS45I8&cshid=1588175916172
*edit..... Nevermind. Seems you've already tried this.
geposted Wed 29 Apr 20 @ 4:01 pm
i'm trying this now and it seems to work and it's free
https://ndi.tv/tools/
geposted Tue 30 Jun 20 @ 11:48 am
A direct NDI plugin would be great (for Videos and for the GUI)
geposted Tue 30 Jun 20 @ 4:18 pm
Native NDI Video Output would be amazing.
Would help with sync.
Scan converter on Mac can be a bit of a nightmare in terms of framerate, especially with waveforms.
Can’t think of a legitimately good reason not to implement this as it’s a fantastic way of getting video in and out of applications, minimal resources.
Killer feature for me would also be if it was possible to have an Aloha output from the video for video skins.
Currently I’m keying out the background, but it’s leaving edges of waveforms a little rough.
Thanks
Thanks
geposted Wed 12 Aug 20 @ 5:37 pm
I am trying to do the same thing. Send the music video output of VDJ to OBS via NDI. I get the DJ screen but not the video output screen. Trying to figure it out. Anyone that has accomplished this, please let us know. Thanks.
geposted Fri 21 Aug 20 @ 4:26 am
I still haven’t found out a solution yet. As anyone else ??
geposted Thu 08 Oct 20 @ 9:16 am
Not a fully native solution :
SpoutReceiver64 can be tested in combination with "NDI to Spout" & "Spout To NDI" right now
geposted Tue 12 Jan 21 @ 9:29 pm
NDI send and receive is now available for windows from extensions
geposted Tue 19 Jul 22 @ 5:05 am
@Adion can you explain that in more detail? There is an update from VirtualDJ with NDI?
geposted Tue 19 Jul 22 @ 8:18 am
It's a plugin, you can install from Config->Extensions->Effects->Video
geposted Tue 19 Jul 22 @ 8:29 am
@Adion
Please also create the NDI plug-in in 32bit!! I can only use Virtual in 32bit!
geposted Tue 19 Jul 22 @ 8:42 am
Benz Werner wrote :
@Adion
You should probably do something about that
I doubt that the 32-bit version will be alive in a couple of years time
geposted Tue 19 Jul 22 @ 11:34 am
Thank you Adion! Please, PLEASE port this extension to Mac as well.
geposted Tue 26 Jul 22 @ 6:53 am
