Discussion about BCaster GFX
Pads for controlling and changing the view of the Broadcaster GFX videoskin(s)
Learn more about the videoskin here: https://virtualdj.com/wiki/BroadcasterGFX.html
For ambient video background for Slideshow see here:
https://virtualdj.com/plugins/?addonid=81124
Update June 2020 :
- easier one-click dual camera operation
- automatic cycle through views
- optional backgrounds with Shader FX
- optional extrabox (for ScreenGrab FX to screen record a live chat etc)
- color scheme
and more....
geposted Wed 27 May 20 @ 6:11 pm
Thank rune, I will give it a run through this evening.... I already using your other beta as of last week as well....
geposted Wed 27 May 20 @ 7:42 pm
Can you tell me what the settings are inside of the custom box? What do I select to have these different things change? Thank you.
geposted Fri 05 Jun 20 @ 4:44 pm
Nevermind, silly me did not realize I had to download the buttons. Thank you for creating this!!!
geposted Fri 05 Jun 20 @ 4:48 pm
More detailed instructions are needed on how o set the cameras up
geposted Sun 07 Jun 20 @ 7:27 pm
Just click "CAM" on the pad ;)
Or enable Camera video FX on the master (mixer area) in the skin.
Thats it ;-)
On how to use the videoskin see here : https://virtualdj.com/wiki/BroadcasterGFX.html
geposted Thu 11 Jun 20 @ 9:55 am
Can see a short guide here also :
See more here : https://virtualdj.com/wiki/how%20to%20use%20camera.html
And for adding your phone as extra camera see here :
https://virtualdj.com/wiki/using%20your%20phone%20as%20webcam.html
geposted Thu 11 Jun 20 @ 12:16 pm
How to delete the twitter from the skin?
geposted Mon 10 Aug 20 @ 3:39 pm
Read the instructions (see first post).
geposted Mon 10 Aug 20 @ 4:01 pm
sorry about that,
im testing all day this video plugin,
now I'm having problems with cycle view, in the firs even 15 sec ativeted , works as 30 sec...now the cycle does works
I'm using MAC, anyone with same problems?
geposted Thu 13 Aug 20 @ 1:05 am
Hi, is there a way to play sample video over whole screen, not in video box? Thank you
geposted Wed 28 Oct 20 @ 11:18 am
Not while using the skin...
You can turn off the skin, and play the sample over whole screen
geposted Wed 28 Oct 20 @ 11:23 am
Thank you
geposted Wed 28 Oct 20 @ 2:53 pm
It could probably be scripted...
If this sample playing? If yes, turn off the videoskin (while it plays).
geposted Wed 28 Oct 20 @ 4:03 pm
Very Dope overlay thanks for creating this.
My script skills are lacking. I cant figure how to
add or get rid of the social media part. (I got be doing something wrong I followed the instruction & no change).
geposted Wed 16 Dec 20 @ 7:31 pm
read the bit on social media tags
geposted Wed 16 Dec 20 @ 8:04 pm
I got it to work! Thanks for this skin once again. Peace...
geposted Wed 16 Dec 20 @ 8:25 pm
I'm having trouble playing videos in the slideshow setting. For some files, like mp4 it works, but for others like webm it doesn't. Anyone find a solution to a similar problem?
geposted Sun 12 Jun 22 @ 4:00 pm
I cannot get the second camera to work in the Broadcaster GFX skin. I have been trying for hours and I read everything there is to read about it :) I have the pads installed, everything. I even read the script to try to understand what the feed is suppose to be, no luck. My two cameras work well individually, I have camera enabled on the Master Video Fx, I can toggle between both using the control of Camera Master, I see them in window number 1 of Broadcaster GFX. The button 2X Cam is pressed but window number 2 of Broadcaster GFX stays black. Where do I set the second camera ?
geposted Mon 04 Jul 22 @ 8:35 pm
