Hello all!
A few years ago, I posted here on the forums asking for help in automatically lowering (and fading) the mic volume. Locodog provided the perfect solution:
Unfortunately, in the latest version of VDJ I can't seem to get this to work.
First, I can't locate custom dials, only custom buttons. Second, the Volume FX add-on is apparently no longer available to download.
Does anyone know how I can achieve this now?
Appreciate your help!
locodog wrote :
@groovin, abandon the previous pm's this is better.
That's not a fade that's a cut.
For an actual fade, it's trickier.
2 Dial, 1 Button Ducking with the Volume FX
first get and install the "Volume" FX
https://virtualdj.com/plugins/?addonid=16845
Put this on a dial (custom or HW, custom will do) This sets the bottom level
(you'll only have to set this once, ever)
Put this on another dial. This sets the rate, slow to very fast, (Over 100%, 7.5s to less than 0.5s )
(it too only needs to be set once)
Put this on a custom_button
set '@$DukLevel' & var_equal '@$DukLevel' 0 ? set '@$DukLevel' "`get_var '@$DukLevel' & param_add 0.01"
set '@$DukRate'
var_equal '$DukVar' 0 ? mic on & deck 1 effect_active "Volume" 1 & deck 2 effect_active "Volume" 1 & deck 1 effect_slider "Volume" 2 60% & deck 2 effect_slider "Volume" 2 60% & set '$DukCounter' 1 & repeat_start_instant 'DukSweep' 10ms 201 & var_greater '@$DukLevel' '$DukCounter' ? set '$DukVar' 1 & repeat_stop 'DukSweep' : var_smaller '@$DukRate' 0.1 ? set '$DukCounter' '`get_var "$DukCounter" & param_add -0.005' & deck 1 effect_slider "Volume" 1 -0.5% & deck 2 effect_slider "Volume" 1 -0.5% : var_smaller '@$DukRate' 0.2 ? set '$DukCounter' '`get_var "$DukCounter" & param_add -0.01' & deck 1 effect_slider "Volume" 1 -1% & deck 2 effect_slider "Volume" 1 -1% : var_smaller '@$DukRate' 0.3 ? set '$DukCounter' '`get_var "$DukCounter" & param_add -0.015' & deck 1 effect_slider "Volume" 1 -1.5% & deck 2 effect_slider "Volume" 1 -1.5% : var_smaller '@$DukRate' 0.4 ? set '$DukCounter' '`get_var "$DukCounter" & param_add -0.02' & deck 1 effect_slider "Volume" 1 -2% & deck 2 effect_slider "Volume" 1 -2% : var_smaller '@$DukRate' 0.5 ? set '$DukCounter' '`get_var "$DukCounter" & param_add -0.025' & deck 1 effect_slider "Volume" 1 -2.5% & deck 2 effect_slider "Volume" 1 -2.5% : var_smaller '@$DukRate' 0.6 ? set '$DukCounter' '`get_var "$DukCounter" & param_add -0.05' & deck 1 effect_slider "Volume" 1 -5% & deck 2 effect_slider "Volume" 1 -5% : var_smaller '@$DukRate' 0.7 ? set '$DukCounter' '`get_var "$DukCounter" & param_add -0.06' & deck 1 effect_slider "Volume" 1 -6% & deck 2 effect_slider "Volume" 1 -6% : var_smaller '@$DukRate' 0.8 ? set '$DukCounter' '`get_var "$DukCounter" & param_add -0.07' & deck 1 effect_slider "Volume" 1 -7% & deck 2 effect_slider "Volume" 1 -7% : var_smaller '@$DukRate' 0.9 ? set '$DukCounter' '`get_var "$DukCounter" & param_add -0.08' & deck 1 effect_slider "Volume" 1 -8% & deck 2 effect_slider "Volume" 1 -8% : var_smaller '@$DukRate' 0.99 ? set '$DukCounter' '`get_var "$DukCounter" & param_add -0.09' & deck 1 effect_slider "Volume" 1 -9% & deck 2 effect_slider "Volume" 1 -9% : set '$DukCounter' '`get_var "$DukCounter" & param_add -0.1' & deck 1 effect_slider "Volume" 1 -10% & deck 2 effect_slider "Volume" 1 -10% : mic off & repeat_start_instant 'DukSweep' 10ms 202 & var_greater '$DukCounter' 1 ? set '$DukVar' 0 & repeat_stop 'DukSweep' & set '$DukCounter' 1 & deck 1 effect_active "Volume" 0 & deck 2 effect_active "Volume" 0 : var_smaller '@$DukRate' 0.1 ? set '$DukCounter' '`get_var "$DukCounter" & param_add +0.005' & deck 1 effect_slider "Volume" 1 +0.5% & deck 2 effect_slider "Volume" 1 +0.5% : var_smaller '@$DukRate' 0.2 ? set '$DukCounter' '`get_var "$DukCounter" & param_add +0.01' & deck 1 effect_slider "Volume" 1 +1% & deck 2 effect_slider "Volume" 1 +1% : var_smaller '@$DukRate' 0.3 ? set '$DukCounter' '`get_var "$DukCounter" & param_add +0.015' & deck 1 effect_slider "Volume" 1 +1.5% & deck 2 effect_slider "Volume" 1 +1.5% : var_smaller '@$DukRate' 0.4 ? set '$DukCounter' '`get_var "$DukCounter" & param_add +0.02' & deck 1 effect_slider "Volume" 1 +2% & deck 2 effect_slider "Volume" 1 +2% : var_smaller '@$DukRate' 0.5 ? set '$DukCounter' '`get_var "$DukCounter" & param_add +0.025' & deck 1 effect_slider "Volume" 1 +2.5% & deck 2 effect_slider "Volume" 1 +2.5% : var_smaller '@$DukRate' 0.6 ? set '$DukCounter' '`get_var "$DukCounter" & param_add +0.05' & deck 1 effect_slider "Volume" 1 +5% & deck 2 effect_slider "Volume" 1 +5% : var_smaller '@$DukRate' 0.7 ? set '$DukCounter' '`get_var "$DukCounter" & param_add +0.06' & deck 1 effect_slider "Volume" 1 +6% & deck 2 effect_slider "Volume" 1 +6% : var_smaller '@$DukRate' 0.8 ? set '$DukCounter' '`get_var "$DukCounter" & param_add +0.07' & deck 1 effect_slider "Volume" 1 +7% & deck 2 effect_slider "Volume" 1 +7% : var_smaller '@$DukRate' 0.9 ? set '$DukCounter' '`get_var "$DukCounter" & param_add +0.08' & deck 1 effect_slider "Volume" 1 +8% & deck 2 effect_slider "Volume" 1 +8% : var_smaller '@$DukRate' 0.99 ? set '$DukCounter' '`get_var "$DukCounter" & param_add +0.09' & deck 1 effect_slider "Volume" 1 +9% & deck 2 effect_slider "Volume" 1 +9% : set '$DukCounter' '`get_var "$DukCounter" & param_add +0.1' & deck 1 effect_slider "Volume" 1 +10% & deck 2 effect_slider "Volume" 1 +10%
geposted Sun 07 Jun 20 @ 11:42 am
It's built to VDJ now, as mic_talkover.
geposted Sun 07 Jun 20 @ 12:10 pm
Thank you!
I just found it and tested it...Is there a way to adjust how low the volume goes and how quickly it fades?
geposted Sun 07 Jun 20 @ 12:18 pm
read description
geposted Sun 07 Jun 20 @ 12:36 pm
Crap...This is why I always got into trouble in school. I don't pay attention.
Thank you!
Thank you!
geposted Sun 07 Jun 20 @ 12:40 pm
