Hi Everyone
I went to download the new version 2021 for windows last night. However when I downloaded it was still the 2020 version? Anyone had the same issue?
Thank you
Thank you
geposted Sat 20 Jun 20 @ 11:25 am
you need 64 bit & win10
geposted Sat 20 Jun 20 @ 11:27 am
Oh really, So it won’t run on Windows 7 ?
geposted Sat 20 Jun 20 @ 11:30 am
No. Windows 7 isn't even a supported OS any more.
geposted Sat 20 Jun 20 @ 11:41 am
looking at your chat i have windows 10 32 bit and cant install
geposted Sat 20 Jun 20 @ 2:22 pm
You'll be able to install 2021, but you won't have the newer features. They are 64bit only.
geposted Sat 20 Jun 20 @ 2:50 pm
I thought 2021 was 64 bit only, with 32 bit being 2020?
geposted Sat 20 Jun 20 @ 3:01 pm
I'm having the same problem and I have a windows 10 64 bit.
geposted Mon 22 Jun 20 @ 10:09 pm
Buenos días tengo el mismo problema Windows 10 y 32 bits que podemos hacer en este caso los que tenemos esta dificultad ?
muchas gracias
muchas gracias
geposted Tue 23 Jun 20 @ 12:49 pm
If your Windows 10 is 32 bits, you cannot run VDJ 2021.
Also you need to post in English or use the correct forum area for your language.
geposted Tue 23 Jun 20 @ 12:53 pm
I have windows 10 64 bit i5 computer and it wont let me download. So am I missing something here
geposted Tue 23 Jun 20 @ 1:18 pm
what do you mean "won't let you download" exactly?
geposted Tue 23 Jun 20 @ 1:24 pm
its the same as vdj 2020 why
geposted Tue 23 Jun 20 @ 4:01 pm
Atomix really need to be clearer on this. On the download page it doesn't mention anywhere the 64bit 2021 is Windows 10 only.
Also having the same build number for two completely different versions?
geposted Tue 23 Jun 20 @ 4:26 pm
It does mention it if you visit the page from a windows 7 pc
geposted Tue 23 Jun 20 @ 4:59 pm
I Have the same problem, I have window 10 pro 64 bit, I'm download the last version, but when I open Virtual DJ say Version V8.4 b5874, How I can get the last version?
geposted Wed 24 Jun 20 @ 2:56 am
Download:
VDJ 2021 x64 - https://virtualdj.com/download/pc
VDJ 2020 x32 - https://virtualdj.com/download/pc32
geposted Wed 24 Jun 20 @ 5:59 am
When I go to download the virtualdj_2021 I keep getting a message the "msi blocked because it could harm your device."
What causes this?
What causes this?
geposted Wed 24 Jun 20 @ 10:39 am
A quick Google tells me this is caused by the SmartScreen filter in Microsoft's Edge browser...
geposted Wed 24 Jun 20 @ 10:51 am
im in the same boat ... got 64 bit and win 10 but no good
geposted Fri 26 Jun 20 @ 10:04 am
