Whenever I add a track to a deck, I cannot hear it, I can only hear it in the preview section.
But whenever I add a sampler from VDJ I can hear it perfectly. I can see the track playing but no sound coming through.
geposted Fri 26 Jun 20 @ 11:42 am
....and your audio config is?
geposted Fri 26 Jun 20 @ 11:46 am
Just listening on headphones, master is set to speakers and headphones to my headphones.
geposted Fri 26 Jun 20 @ 11:47 am
Do you have speakers connected? If that's where your master signal is going, they need to exist or you won't hear the signal.
geposted Fri 26 Jun 20 @ 11:49 am
I can hear the speakers, but what I'm trying to say is that the tracks that I import onto VDJ are not playing, only the samplers are playing.
geposted Fri 26 Jun 20 @ 11:50 am
Add me on Discord and I'll show you what I'm talking about. Nacho#2271
geposted Fri 26 Jun 20 @ 11:53 am
OK so you've got speakers and headphones connected?
Earlier you said that you couldn't hear a track on a deck. So where can't you hear it, if you can hear the speakers?
Best thing is for you to post a pic of your audio config.
geposted Fri 26 Jun 20 @ 12:00 pm
Got it to work by resetting options.
geposted Fri 26 Jun 20 @ 12:02 pm
