I use a pioneer SB2 2020 virtual dj software the version prior to the new 2021 software (but come to think of it Ive had this problem on the version previous to that as well.), The issue is it freezesb almost always on the right turntable, It usually does happen when I'm searching through a track or video using my jog wheel on the hardware. When I get in that predicament I try to get it going before the next track ends. I tried using the shift button on the controller while pushing play or cue after, The only way I have been successful of avoid silence over the air waves is I turn vdj into 4 turntables sometimes with the mouse but mostly with the button on my controller, I'm trying to avoid having to restart the software to get it going again. My I have 4 gigs of ram with Win 10.
geposted Sun 28 Jun 20 @ 9:18 pm
The Pioneer SB2 is a controller with jog wheels. You don't have turntables.
4GB doesn't seem very much. What's the spec of your computer? How old is it?
What's your CPU meter doing when you search through a track?
geposted Sun 28 Jun 20 @ 9:42 pm
