I remapped my Fader Cuts button to switch to beatjump instead with
pad_page 'Beatjump'
It works, but I'm still getting the Fader cuts effect, does anyone know how to change this?
pad_page 'Beatjump'
geposted Mon 29 Jun 20 @ 5:04 am
The Fader Cuts mode of Platinum FX cannot be assigned to any other Pads page, other than the pre-defined "Fader cuts" one. Reason is because in this mode, the device is sending several Midi notes, so it's a "hardware" mode as mentioned in the manual and these extra messages cannot be "muted"
geposted Mon 29 Jun 20 @ 5:28 am
Its possible use that pad mode in other controller? What could be the scripts?
geposted Thu 28 Jan 21 @ 2:05 am
No, because that controller will not be sending the needed extra midi codes
It's simply to be considered a hardware based feature on that specific controller
geposted Thu 28 Jan 21 @ 12:41 pm
I think it's just a "cut" Effect, so you can use the Cut FX or/and create your own Custom Pads page
geposted Thu 28 Jan 21 @ 1:10 pm
