Hi there
This is how VDJ scripting works (from the wiki page):
> Using "command1 ? command2 : command3" will query the state of command1, and if the result is true, execute command2, otherwise execute command3.
Its OK, but im trying this now:
"command1 ? command2 : command3 & command4 ? command5 : command6"
The problem now is: command 4 will just be executed if command 1 was false. It looks like:
"command1 ? command2 : (command3 & command4 ? command5 : command6 )"
How can i let run command4 independendly of the result of command1? Like this:
"(command1 ? command2 : command3) & (command4 ? command5 : command6)"
Or like batch scripting:
command1 ? command2 : command3 {/end if}
command4 ? command5 : command6 {/end if}
command7 ? command8 : command9 {/end if}
geposted Fri 03 Jul 20 @ 8:27 pm
that's something not possible (and asked for years ): parenthesis please^^
does interpret as
in a way to do
you have to duplicate the code
"command1 ? command2 & command4 ? command5 : command6 : command3 & command4 ? command5 : command6
does interpret as
in a way to do
geposted Fri 03 Jul 20 @ 11:11 pm
Thank you, Nico
This will be infinite, if i want 20 commands of them :c)
geposted Sat 04 Jul 20 @ 11:00 am
does it really have to be instant?
if not you could use a repeat_start with a counter
set '$someCounter' 0 & repeat_start 'someRepeat' 25ms 20 & cycle '$someCounter' 20 & var '$someCounter' 1 ? Something : var '$someCounter' 2 ? Something Else :
geposted Sat 04 Jul 20 @ 11:28 am
Nice idea, locodog...
Batch scripting for runaways :c)
geposted Sat 04 Jul 20 @ 1:08 pm
parentheses have been requested many times but there must be some technical reason why it can't happen.
method above is ok but for actual time critical things I'd like to see a zero time version of repeat_start that would work a bit like a for loop, but used wrong it could lead to stability issues.
I know of one hacky method which appears stable for a few thousand counter++ cycles but I've only ever used it experimentally.
geposted Sat 04 Jul 20 @ 2:54 pm
