So i like to use a hot key to swap skins ex: load_skin "phantomdj:Preparation mode" works just like I want. I cant seem to figure out to hot key the script for the default pro. I've done the dennYo skin which is the main one I use. I want to try the default a bit without going to the menu to do it.
Thanks in advance
Joe
Thanks in advance
Joe
geposted Tue 07 Jul 20 @ 10:34 pm
I use this .... load_skin 'default:pro'
geposted Wed 08 Jul 20 @ 1:22 am
When I use that it brings me to the starter skin.
geposted Wed 08 Jul 20 @ 1:25 am
Indeed it does. I hadn't noticed that. I actually use a modified pro skin with a button to bring me back but it is in the same folder as my primary skin.
geposted Wed 08 Jul 20 @ 2:02 am
So I dont use the default part, just this.
rightclick="load_skin ':pro'"
geposted Wed 08 Jul 20 @ 2:04 am
I also noticed that the modified pro is taking me back to the old version of pro. I guess I haven't been much help...
geposted Wed 08 Jul 20 @ 2:34 am
you can use
switch_skin_variation ':pro'
instead; difference being to keep current skin (instead of default)
geposted Wed 08 Jul 20 @ 3:40 am
Apparently capitalization matters. This works for me.. load_skin 'Default:Pro'
geposted Wed 08 Jul 20 @ 3:49 am
It works for me to. Thanks I never tried the capitalization.
geposted Wed 08 Jul 20 @ 1:02 pm
