Hello, I'm considering buying the Home Plus license but i have two questions.
How many pc's can i run VDJ on at any one time with this single license and would i have to purchase another license if my controller got damaged or could i just purchase a new controller and use it on the same license?
geposted Wed 15 Jul 20 @ 4:09 am
if you replaced with the exact same mark & model of controller that would work.
geposted Wed 15 Jul 20 @ 4:31 am
VDJ allows you to have the software installed on up to two computers at any one time, providing that they are both for your own personal use and will not be used simultaneously.
geposted Wed 15 Jul 20 @ 7:13 am
Not exactly. You can install it (and use it) on as many computers as you want.
However there is a limit to how many can be used at the same time. VDJ can be logged in on two computers at the same time (main and backup).
If you log in to a third, that will log one of the others out.
geposted Wed 15 Jul 20 @ 7:19 am
That sounds decent. Thanks eveyone for the replys.
geposted Wed 15 Jul 20 @ 4:01 pm
