Nicotux wrote :
That's exactly what i experimented it a early post ^^
https://virtualdj.com/forums/237030/Music_discussion/Fun_use_of_stems.html
giving this https://imgur.com/a/v61OzC5
hey nicotux, very cool!
can you share your <window> code for stems window you have created there ?
would rly love to have a play around with it...
how do you have it set up ? do your stem channels output to virtual audio cables ?
-this one
geposted Tue 15 Sep 20 @ 12:14 am
It's part of experimental skin "vb_8Decks" i use for experiment (would need 10 decks)
"xfaders" windows
https://virtualdj.com/plugins/?addonid=81157
create 3 dedicated custom buttons for deck 1,2,3,4
do the same for 5,6,7,8 replacing deck number
"stemload": deck 1 load & only_stem rhythm & stem_pad rhythm & deck 2 load & stem_pad isolate bass & deck 3 load & stem_pad isolate instru & deck 4 load & stem_pad isolate vocal
"stemstop" : deck 1 stop & deck 3 stop & deck 4 stop & deck 2 stop_button & clone_deck 1 & clone_deck 3 & clone_deck 4
"stemplay": crossfader 100% & crossfader 50%
faderstart & faderstop have to be on
decks 1,2,3,4 affected to left of crossfader
decks 5,6:,7,8 affected to right of crossfader
"xfaders" windows
geposted Tue 15 Sep 20 @ 7:10 am
